Kammo try this one. R12 version but maybe it will work for you.
No greater love can a man have than this, that he give his life for a friend.
UCCNC 2017 Screenset
Gerry are talking about something like a 3ds mesh, polygons?
Mike
Kammo1,
Try this file.
Sorry about that. I have ACAD 2006 and had no problem. I will try to post an earlier version later today.
ger21,
Try this one please.
I can check tomorrow with 2002 at work. However, there are no surfaces or meshes in the .dxf. There's enough info to get the neck shape, but nothing for the carved top. Getting closer, though.
ger21, buddy, I can give you this file in any flavor you want. I have a pristine solid of it.
Name it and you got it.
Thanks, but I don't need it. Just pointing it out for others.
I would think you can save a .dxf from rhino that converted the nurbs to meshes, but I don't know how to do it.
And waist one of my last 23 saves?
I managed to open the file Mike many thanks, is this just a flat top Les Paul as I couldn't see any indication of the carved surface that you see on a Les Paul top or am I doing something wrong ?? would lovr to see the guitar with a carved top many thanks again
Okay my fellow Les Paul Carve Top enthusiasts here is a file I hope you can all use.
P.S. Sorry not you ACAD "only" guys....
Hi Mike I saved the file which is an igs file but Autocad will not open the file, it must be me am I doing something wrong. I have Autocad 2005. Magnus the file you sent me which was a sat file Autocad will not open either. Many thanks guys for being helpful and patient CHEERS! Would it help if I rename the file as .dxf or.dwg would this help before I screw it all up.
AutoCAD won't open iges, but can import some versions of .sat. But you don't use "open" with an .sat file. Try Insert > ACIS file
Kammo1,
As I stated in Post #35, "P.S. Sorry NOT you ACAD "only" guys...." I will try to post an ACAD file you CAN read today (SAT.)
Mike sorry I didn't read the post correctly, ger21 I don't understand when you say insert ACIS file where do I do this ?, oh boy this is getting frustrating as my computer knowledge isn't very good and without understanding what, to do where and when I feel like I'm going around in circles........
