Stratocaster Pickguard
Results 1 to 12 of 12
Thread: Stratocaster Pickguard
    Sep 2010
    Default Stratocaster Pickguard
    Hello!
    I am working on a guitar, and I need to design a custom pickguard for it. Does anyone have an existing AutoCAD file that I could modify and pass on for laser cutting? This is for a 2008 Fender Squier Stratocaster Affinity. I have Googled and googled, and I have looked through these forums, but I have had trouble finding a pickguard file.
    Jul 2009
    Belgium
    Hello hh73,
    Here are two zipped dxf strats with pickguard included and one pdf of four pages if you can convert it, I think there will be no problems to make your custom made pickguard with these files, hope it will be of some help.
    Ciao, Ciao
    georgy1
    Attached Thumbnails Attached Thumbnails Stratocaster Pickguard-fender-stratocaster-pick-guards-4-pages-pdf
    Attached Files Attached Files
    Jul 2012
    Quote Originally Posted by georgy1 View Post
    Hello hh73,
    Ciao, Ciao
    georgy1
    I know this was a long long time ago, but I just happen to find this old topic from a Google search. I was wondering, do you have a Jaguar and Jazzmaster pdf like these?
    May 2006
    Try the fender website it is a source
    If you can find a PDF of the original,
    problem now solved convert to DXF
    if not, digitize an existing pickguard.
    Been doing this too long
    Jul 2012
    Quote Originally Posted by bostosh View Post
    I looked around on the site and couldn't find anything. I searched went to every tab and couldn't find anything. If you have a better idea than I sure would love the help. Thanks.
    May 2006
    HERE IT IS
    download the pdf file and convert to dxf and machine it.
    Fender® Support
    To steal ideas from one person is plagiarism.
    To steal from many is research.
  7. #7
    Jul 2012
    HERE IT IS
    Fender® Support
    Thanks that did help me locate the area where the diagrams were thank you, but I needed one for a Jaguar and Jazzmaster. Those just seem to be basic hand manuals and not specifically for the pick guards.
  8. #8
    Jul 2013
    how do you conver a PDF to a DXF?
  9. #9
    Dec 2006
    germany
    you don´t need to convert the PDF into dxf! You can load the file direct into Adobe Illustrator, Corel Draw or Rhino! As it is a VECTOR format it will open and you can do whatever you want with it.....scale, covert into iges, dxf ....etc.
    Please note that the fender diagramms are PDF but not scaled and if scaled they are not accurate. For example the dimensions will not fit if 1:1...
    The best aproach is to get hands on the real thing and do the drawings from there!
  10. #10
    Apr 2018
    Brazil
    Default Re: Stratocaster Pickguard
    Hello hh73,
    Ciao, Ciao
    georgy1
    Thanks a lot, georgy1, I've been looking for a file on the internet for the whole 5 days searching. THANK YOU SO MUCH!
  11. #11
    May 2006
    Grabcad is worth looking
    I assumed you wanted the file for free?
    Try Georgia Luthiers Supply CNC
    Good guaranteed tested plans, your choice !
  12. #12
    Activation process Glockner's Avatar
    Sep 2018
    Thanks!!!
