- Multicam 3000 not saving parameters?
Hi, I have a Multicam 3000 router. I bought it used and the last guy messed up the ATC parameters. So for now I am manually changing the tools. I have "Machine Tools Suite 4.0" , which has a couple of programs that allow me to make changes to the parameters. The main program, "MachineParameters4.exe" brings up a list of parameters with little input boxes. However, the parameters I need to change (900-950) do not have input boxes, so I cant make any changes. Under machine tools-->connection manager-->settings I can manually make changes to the XMI parameter file, but none of these changes are reflected in the machine. Does anyone have experience with this?
Re: Multicam 3000 not saving parameters?
It is better to change parameters in motion mechanic or thru the keypad. 900-950 are tool change locations. A macro (program) is used to set the alignment of each tool position. Dont change any parameters unless you know what you are doing.
- You may not post replies
- You may not edit your posts
Forum Rules
