- Getting Vision Up & Running w/ Multicam
Hello All,
I am tasked with getting our Multicam camera functionality up & running again after we lost our operator.
I was able to get the camera calibrated & the camera offsets set. When I attempt to program a simple test cut... The Multicam will read all regmarks, then it pauses right before it is supposed to do the tool change for the final Cut.
The G-Code looks OK, from what I can tell, and there are no "extra point or lines" left over, that could cause an issue.
I am fresh out of ideas.... Our VISION tool is setup as Tool 99 in our enroute tool library, but I do not see a place to mirror that in the Multicam / Job Console.
Any help would be much appreciated.
Thanks,
K. Vallery
- You may not post replies
- You may not edit your posts
Forum Rules
