- Need Help!- Error Loading Material Multicam 6000
Activation process
Im using a Multicam 6000 series with a Hypertherm Plasma Cutter. Machine communication is fine, I can load programs but right before the machine starts a job, controller says "Error Loading Material". I've also tried HD ComTst and controller says No Response from HD. Any ideas on what might be wrong? I think it might have something to do with low Air/O2 pressure but im not sure, Is there a way to test this?
- You may not post replies
- You may not edit your posts
Forum Rules
