Need Help! Multicam 3000 2005 machine Teknic SST-1500-561
Results 1 to 11 of 11
Thread: Multicam 3000 2005 machine Teknic SST-1500-561
    Mar 2017
    Angry Multicam 3000 2005 machine Teknic SST-1500-561
    Hello, I was wondering if anyone else received a call from Multicam East today? They told me that the Teknic Drives that Control the servo motors would not be made anymore or serviced. (There are 4 in this machine.)
    Basically starting in March 2022 the only way if I had a problem would be to update the whole control box for around $20,000.00 dollars.
    These drives usually go for around $1200.00 dollars a pc programed.
    I asked them if I bought a bunch of these if there would be a way to program for each servo motor axis as needed?
    They said they would get back to me on that.
    Anyone familiar with these Teknic drives and what can I do to keep this machine running without paying over $20,000 if I run into a bad drive?
    Thank you
    Jimmy
    Dec 2013
    Default Re: Multicam 3000 2005 machine Teknic SST-1500-561
    You have a lot of options that don't include Multicam. Sounds like they are trying to sell upgrades by scaring the customers.
    DMM and Delta servos are a direct replacement, and the Teknik ClearPath product line will also replace them. It is also possible that Teknik also has a direct replacement. Setting up new servos is a bit of a PITA when hampered by the Multicam software, but it is doable, I have done it.
    If it were my machine, at the first sign of servo problems, I would rip out everything that says Multicam on it and do a full upgrade, and it would cost a heck of a lot less than $20K, including all new servos.
    If you really want to go cheap, hybrid steppers from eBay would work just fine.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2013
    the only problem with Teknics is that they are expensive for what you get.
    Look at this, a 1.5kW Delta B2 servo/drive and cables for $750:
    https://www.fasttobuy.com/cnc-router...le_p28102.html
    That's less than you'd pay for a Teknics drive alone. If you want value for money these 750W Delta B2 series servo/drive and cables for $438:
    https://www.fasttobuy.com/flange-80m...er_p28084.html
    Craig
    Jun 2010
    Multicam told you kind of half the story, Teknics is phasing out those drives but they have not yet. They will keeping building drives until all the parts required to build those drives run out.
    Give Motioin Solutions a call 949-699-6431 they are the only distributor for Teknics drives
    Quote Originally Posted by Verucktjim View Post
    Thank you
    Jimmy
    Member Gebrateq's Avatar
    Oct 2019
    Quote Originally Posted by Jim Dawson View Post
    Hi Jim
    My Multicam machine has been "broken" for six weeks now (XA drive to high supply voltage blink code 3) and even though i allready forked out and paid the local agent (South Africa) for a new drive, week by week they (Multicam USA according to local guy) change their story and yesterday they basically said, sorry no drives available (and i hope to get my money back). We did multitude of swaps and tests etc to deduct that that particular servo drive is faulty and not the motor or cable.
    PLEASE advice me how to do the drive swapp out you mentioned above. I am getting "desperate"
    Kind regards Johan
    Activation process ptmachinery's Avatar
    Jun 2018
    Any luck. Now I need one. SST-1500-561
    Or do the other 1500 models work?
    Can still find some 103 on ebay
    What about good repair options?
    Quote Originally Posted by Gebrateq View Post
    Hi Jim
    Kind regards Johan
  7. #7
    ejbs's Avatar
    May 2023
    Hello! My boss is changing the business and take down the Multicam 3000. He is selling the 4 Teknic SST-1500-561 drivers. If you are still looking for that I'll be in contact.
    Regards,
    Enrique B.
    https://ibb.co/6X9CQYp
    https://ibb.co/vkz8TJQ
    https://ibb.co/SXbLyCP
    Attached Thumbnails Attached Thumbnails Multicam 3000 2005 machine Teknic SST-1500-561-20230504_142207-jpg   Multicam 3000 2005 machine Teknic SST-1500-561-20230504_141927-jpg   Multicam 3000 2005 machine Teknic SST-1500-561-20230504_141853-jpg
  8. #8
    ejbs's Avatar
    May 2023
    Quote Originally Posted by ptmachinery View Post
    Regards,
    Enrique B.
  9. #9
    Jun 2018
    yes still looking are these available ?
  10. #10
    ejbs's Avatar
    May 2023
    Yes. Available the 4 Teknic SST-1500-561 drivers
  11. #11
    Member FBianchini's Avatar
    Jun 2023
    please contact me at fernando.bianchini@dezenho.ind.br I need 1 unit from this drive
  12. #12
    ejbs's Avatar
    May 2023
  13. #13
    Rasta1pa's Avatar
    Jul 2023
    Hello Enrique,
    Are the drives still available?
  14. #14
    Rasta1pa's Avatar
    Jul 2023
    Enrique, Please semd me your contact number. My number is (202) 604-9456
  15. #15
    Catfish80's Avatar
    Jul 2023
    Quote Originally Posted by ejbs View Post
    I need one or more of these drives.
    Contact me please. (714) 673-8880
