MultiCam 3000
Results 1 to 4 of 4
Thread: MultiCam 3000
    Member Rusty48's Avatar
    Jan 2022
    Default MultiCam 3000
    motor fault (0x 1) XA Drive 1-faulted Axis 0 3000_545_3422_XA Count 9: Drive is OK Safety stop basis: Bad hall
    I keep getting this message at startup. Any thoughts
    Jun 2005
    Default Re: MultiCam 3000
    This message seems to suggest you have a loose or perhaps a Hall effect homing sensor that is going bad.
    Jan 2022
    Quote Originally Posted by CNCMAN172 View Post
    Excellent, thanks for the info. When I try to home the machine, at startup, it almost appears to try to make a rapid move then stops. I can see the Y and Z axis move, then the X axis starts to travel and that’s it….shut down. Thank you for your help.
    Jun 2005
    Quote Originally Posted by Rusty48 View Post
    This happens because the controller starts to home and sees that the home sensor a hall effect sensor has fired meaning it is already there to it stops motion. Check the hall effect sensor on the X axis. It is either bad or it is loose and near a piece of metal causing the problem. They are not that expensive you could order a new on and you would be in good shape.
    Russ
MultiCam 3000
MultiCam 3000
