- Need Help!- Does anyone have a H4ldr.uc file?
I lost User Init in my Multicam 1000
I accidentally wrote down the parameters of the machine in "User Init"
Because they are similar in format "cts"
Now I need "H4ldr.uc" to write it down in "User Init" NVRAM
Just in case I will write the parameters of the machine:
****Router Machine S/N M2400****
Loader V6.70
Standard V6.70
MCIF V4.41a
uCITO V2.06c
Keypad KDM20 V1.20
Controller :
LC520 Rev 2 Interface M64 (ID 22)
Serial Num #2400
Speed 133MHz
Memory 8M
Step Delay ON
IP Address 192.168.0.88(255.255.240.0)
Bus Voltage 36.178 VDC
Module Information
MODULE INI_STD 2 6.70
MODULE INI_MD4 20 1.28
MODULE INI_INIT -3 6.70
MODULE INI_INVERTER 5 2.19
MODULE INI_SELFTEST 1 0.00
FIRMWARE 4.41a
SERIAL_NUM 2400
FEATURES 199485
MEMORY 3
MPU_MHZ 133
CONTROLLER_REV 2
CONTROLLER LC520
Re: Does anyone have a H4ldr.uc file?
I found the original parameters file.
And I received the "User Init H4ldr.uc" file from the Multicam service center in Russia
The machine is repaired, everything works!
- You may not post replies
- You may not edit your posts
Forum Rules
