- X position off
X position off
Recently we had out Multicam MG Series CNC have a Xservo fault. We were able to fix that problem, but now the CNC thinks that the X0Y0 position is about 2 inches off the table from where it actually is. This makes it impossible to measure our cutting bits as it can't touch off the plate. We are using WinCNC, but can't find a way to change the absolute coordinates, only the local and temp ones.
- X position off
- You may not post replies
- You may not edit your posts
Forum Rules
