Need Help! RS-232 cable for M2521 Milticam 3000
Results 1 to 4 of 4
Thread: RS-232 cable for M2521 Milticam 3000
    Member Andy_kap's Avatar
    Jan 2021
    Default RS-232 cable for M2521 Milticam 3000
    Hi, in our M2521 TCP port failed. I have to use Com-port RS-232.
    I have drawn up a connection scheme and manufactured the cable.
    But Multicam 3000 does not connect to PC.
    ?an you give a scheme of the cable and settings RS-232 for PC?
    Attached Thumbnails Attached Thumbnails RS-232 cable for M2521 Milticam 3000-2521_1-jpg   RS-232 cable for M2521 Milticam 3000-comm-jpg
    Sep 2006
    Default Re: RS-232 cable for M2521 Milticam 3000
    Not sure about the MC 3000 but the older MC's that used a Serial cable for connection to the computer, and used WinDNC (Win98) or MX32 to transfer files. If i'm not mistaken a DB-9 Null Modem cable is needed..
    Jan 2021
    The problem is solved. I added CTS wire in the cable to the eight pin. I used 'Motion Connection' and 'Job Server' programs.
    Feb 2022
    Quote Originally Posted by Andy_kap View Post
    Is it work fine with it now via RS232 and without ethernet?
    Please could you share that soft to try. Unfortunally we have the same situation...
