- Need Help!- Help with machine default setting code Multicam 3000
I need to change the default tool lift parameter in the machine code for the pendant.
Because of how I need to set up the machine material height and bed height to run a certain type of file, I have to set the lift height in Machine parameters every time I start up the machine.
The machine default is 0.5" and I would like to have it default to 1.0" so it is guaranteed to start above a 3/4" plywood sheet on startup.
Does anyone have some experience in permanently setting the machine default parameters so they stick in the pendant at startup.
I am not a CNC programer or code jockey. I use Fusion 360 as my design software and the heights do work.
Mahalo I'm in Hawaii.
- You may not post replies
- You may not edit your posts
Forum Rules
