- Need Help!- Looking for a new Z axis belt for my Multicam 3000
The existing belt is now non-existent, it literally fell to pieces while running the machine today. So I don't have the old one to look at or measure and I cannot seem to locate any part guide for this machine. So I was wondering if anyone can help with a part number or source? It looks to be 158x10mm from my measurements, but I'm not sure what the tooth count needs to be. Also, judge from the thin "wire" I had to clean up around the pulled, I assume this belt needs to be reinforced with metal or carbon threading?
I believe its year of manufacture is 2008 and its a 5x10 with ATC if that matters.
Thanks, In Advance.
Re: Looking for a new Z axis belt for my Multicam 3000
OK, I have done some hunting online and a bunch of math.... I believe the size belt I need is 365mm and 10 mm wide with a 5mm pitch. Trade# T5-365-10 can anyone confirm?
...good hunting. More charts of belts/ timing type
https://www.mcmaster.com/timing-belts
DJ
Just an update.
The T5-365-10 was too big. Even with the motor adjusted all the way out on the slotted mounts there is still too much slack, but only just a hair. I just ordered a T5-355-10 which should do the trick.
- You may not post replies
- You may not edit your posts
Forum Rules
