- Need Help!- MultiCAM-MT510
MultiCAM-MT510
The lifting cable (front right) is broken.
Most likely wear and tear.
It was decided to replace not only this cable, but also the left one.
The central one was not changed.
The replacement procedure was not easy.
There were many unsuccessful attempts.
Finally, the left cable was replaced.
With two cables they began to check the machine.
After turning on the machine and starting Find Home, when the table moves along X at the very end, there is a sharp knock and stop
System Interupt: X Home
I ask for help.
Re: MultiCAM-MT510
Lifting Cable....you might want to upload some picture on the site here to give better idea of what you are talking about
- You may not post replies
- You may not edit your posts
Forum Rules
