Need Help! Multicam not booting properly
Results 1 to 9 of 9
Thread: Multicam not booting properly
    Dec 2011
    Default Multicam not booting properly
    Good day folks,
    I picked up a used multicam a few weeks ago. It had a few gremlins at first, but has been running well.
    Today I went to turn on and got a few errors.
    Parameter error 52 59
    ISP stack error 46 in 'drop'
    And the hand controller is showing weird characters.
    I have 5v to the board, nothing is on their homing or limit switches, the emergency switch isn't triggered.
    I can get past the multicam logo on the controller, but then just the weird characters. Can't go further.
    Any ideas? I have work that needs to be cut asap(then again has a CNC ever broke when it wasn't needed?)
    Thank you.
    Jun 2010
    Default Re: Multicam not booting properly
    What is the exact reading at the control board?
    Dec 2011
    Quote Originally Posted by MCPservice View Post
    Good day,
    Do you mean the supply voltage? It is 5.01v. It was at 5.06v and i turned it down.
    Or did you mean something else?
    Thank you
    Dec 2011
    My voltmeter reads 5.01v at the leads at the block on the control board.
    Also the board has all green lights. The VFD seems off and has no lights .
    Jun 2010
    Voltage should be at 5.09 at the control board.
    If your voltage is good there, does the keypad show your normal X,Y and Z screen
    Dec 2011
    Good day,
    Voltage was good.
    No just some "Russian" looking characters.
    Motion mechanic still show the same errors.
    Thank you
  7. #7
    Jun 2010
    What model machine is this?
    Quote Originally Posted by Torontocnc View Post
    Good day,
    Voltage was good.
    Thank you
  8. #8
    Dec 2011
    M204 from 2003
  9. #9
    Jun 2010
    Would you happen to have a copy of your old parameter file?
