Originally Posted by
Deese
I have a MG205 build date 10/2000 sticker in the control cabinet. I have a windows7 64 bit pc with pss installed. Machine connections finds the router. Job server starts and shows connection established to the router,the server icon is active in the tray. You push the dnc button on the pendant and the "loading....." message displays, timeout occured waiting for a feature key pop up window on the pc displays. Or you hit the dnc key and it will show Host Not Responding. There is a direct connection from the pc to the m24 control. Multicam says it doesnt need a switch for win7. both contol and pc have a discreet ip address with the same subnet mask. Sometimes when you start the machine,and the pc up it will connect,but it is very rare for it to connect and this is just not acceptable.
