- power fault, power glitches.
thiis morning income in kicked on my MC mg204, it went straight to a power fault, after resetting I got it to setup and run one sheet, on the second sheet it faulted power glitches, reset, same thing..
looking through older threads i found the adjustment procedure for the 5vdc, it started at 6.4, so I adjusted it down, it will only drop to 5.90, and now the machine when booted, goes into a "multicam kdm v3.03 screen on the touchpad, and will not reset or do anything else.
I have a 5vdc box coming, just hoping someone has other ideas
Re: power fault, power glitches.
Replace your 5 volt power supply......don't thing your meter is showing the correct voltage....normally when the power supply fails it fails downward, not up .....
- You may not post replies
- You may not edit your posts
Forum Rules
