The real question is: Is it a real fault, shown on the inverter display, or does the controller just think it's getting a fault signal from the inverter? The former may be a problem with the inverter, the latter could be just a loose wire.
Keep getting "System Interrrupt: Inverter Fault".
Machine has a Yaskawa GPD 506/P5 Inverter.
I am sure the dust in cabinet hasn't helped, have cleaned out cabinet and inverter but problem seems to be gradually getting worse. Used to happen once a day and now it happens every couple sheets I cut.
Any suggestions would be great.
Jim Dawson
Sandy, Oregon, USA
The Inverter is showing EF3 - Ext Fault 3
I did check to make sure all the terminals were tight on the inverter. Next I guess I should probably check the whole panel for loose wires.
That being the case, I would check the electrical diagrams to see what terminal triggers an external fault on the inverter. Then follow that wire back to the source.
Jim Dawson
Sandy, Oregon, USA
What wire is going to terminal 3 on the inverter?
And what model machine do you have?
