Newbie cabinet software for multicam pro 102 produced 2009
Results 1 to 6 of 6
Thread: cabinet software for multicam pro 102 produced 2009
    Member Tribald's Avatar
    Jun 2019
    Default cabinet software for multicam pro 102 produced 2009
    Hi
    great information here amazing!
    I have a chance to buy a functioning multicam cnc pro series 102 produced in 2009
    my question is does anyone know what cabinet software would work with this machine?
    any info is greatly appreciated
    the machine is 10K
    its going to cost me 10k just to ship a new machine to my location, Oahu Hawaii
    thanks
    Sep 2006
    Default Re: cabinet software for multicam pro 102 produced 2009
    Any software that generates GCode or PLT files. Cabinet software may be limited depending on what options and tooling the MC Pro has. Does it have ATC? Multiple Spindles? Drill Bank? Saw Head?
    These can make cabinet production faster and easier. If it has just one spindle then you'll be limited and you'll be doing a lot of manual tool changing.
    Neal
    Jun 2010
    Quote Originally Posted by Tribald View Post
    Hi
    the machine is 10K
    thanks
    QUESTION?
    You might want to get some pictures and videos of this machine Pro/MG series machine were MFG in like 2000-03/04. Then the thousand series machine started the 1000,3000,5000 series machine, where is this machine because you might be buying a 10K paper weight, spend the money for a inspection, it may keep you from having buyer remorse.
    There are also some things to be aware of with this machine, namely the control board.
    Sep 2006
    My MC Pro 102, with 2 - Z's was built in 1999. I bought it in 2005, still in use today never had a problem, knock on wood. Spent it's early years cutting .5" BB PLy Dinosaurs 24/7.
    Neal
    Attached Thumbnails Attached Thumbnails cabinet software for multicam pro 102 produced 2009-cnc-router-jpg
    Jun 2019
    hi
    yes this machine was produced in 1999
    im truly frightened of this machine but for 2K hopefully with some luck and some more $ i can make it work
    it seemed to work ok at previous owners shop, but did have some glitches.
    whats the main issue with the control boards on these machines?
    I appreciate the knowledge and info for sure
    Ian
    Jun 2019
    hi
    glad to see one of these still going! As of now, I own this thing.
    its a single spindle 7.5 HP 5 x 10 table with ATC
    multicam pro series 102 produced in 1999
    seems to be a bit of a dinosaur itself.
    what do you mainly use your machine for?
