Multicam CNC Router 1000 series
Results 1 to 4 of 4
Thread: Multicam CNC Router 1000 series
    FSSchmidt's Avatar
    Feb 2019
    Default Multicam CNC Router 1000 series
    Hey, I'm having troubles getting the depth to set on my router. I don't know if it's a suction or mill problem. The depth won't set for any bits including our mill bit. Any help appreciated.
    Member he1957's Avatar
    Jun 2018
    Tasmania
    Default Re: Multicam CNC Router 1000 series
    What happens when you try? Describe the behaviour.
    Did it work before?
    What's changed between when it worked (assuming it did) and now?
    Jun 2010
    Explain what happens when you try to calibrate.
    Is it immediately going up when you hit your 0 key or does it keep going down, and acts like it doesn't see the block.
    Sep 2006
    I had a similar problem. Turned out the surface block wire had broken internally. Check it for continuity.
