- Need Help!- Multicam 1000 Router Recommended air dryer?
‹Hey folks, we've got a machine on the way in a couple of weeks and we're trying to set up for it.
1103 series Multicam router 5X10 using it for cutting composite materials
I'm trying to get a recommendation on I believe what is called an air dryer? Notes from Multicam below.
Do any of you have a recommendation that you've had GOOD results with on a comparable multicam?
Our compressor is a single stage 60 gal 155 max psi 16.1 CFM @ 40psi 14CFM @ 90 psi
__________________________________________________ _______________________________
What our spindle manufactures require is clean dry air. The air needs to be free of oil, water, and particulates. I have listed their specifications below.
4.6 Pneumatic connections
4.6.1 Specifications for compressed air to be supplied to HSD products
Inject compressed air with a purity rating complying with ISO 8573-1, types 2, 4, 3,
i.e:
• Type 2 for solid particles: size of solid particles < 1 ìm.
• Type 4 for humidity: dew point < 3°C (37.4°F).
• Type 3 for total oil: oil concentration < 1 mg/m3.
Failure to comply with these specifications may result in electrospindle
malfunction.
The warranty is not valid if pollutants are found during repair operations.
- You may not post replies
- You may not edit your posts
Forum Rules
