Give me a call....need more information.....
678-548-1483
Maurice
Hi
My machine is multicam 1000 series wood cut
please i need help, this problem happens while am doing warming up for spindle then timer in the control show 5:21 and control forzed, i turned machine off by mail switch and then i turned it again showed this message in the control LCD.
please how can i fix it :,(
message in the picture and also video form inside the cabinet
thanks,
678-548-1483
Maurice
am not in US now, please can i contact you on Skype please, if yes please give me your Skype ID.
i sent you SMS
sorry don have a Skyp account, that a pic and post of your control cabinet. Also when you home out the machine, the inverter comes on with out any fault correct?
Cant be the inverter is programmed internally, and should not change. Plus the spindle warm up is a internal program to the controller not motion control. When you request the spindle warm up, what shows up on the keypad.
- - - Updated - - -
yes but I am about to get on a flight.....it will be Monday before I am available after 12 today eastern
its showed timer down 5minCant be the inverter is programmed internally, and should not change. Plus the spindle warm up is a internal program to the controller not motion control. When you request the spindle warm up, what shows up on the keypad.
after u pressed enter to warm up the keypad showed warming up 6000 RPM and timer suddenly freeze at 4min:21sec ,then i shutdown the machine from main switch and turned it again showed that message (KDM20 v1.37) , but when when i pressing the arrow key spindle is moving and the machine get the order from keypad but the information not showed in keypad LCD just (KDM20 v1.37) nothing else.
okyes but I am about to get on a flight.....it will be Monday before I am available after 12 today eastern
What is your incoming power are you single or three phase. Then check to see how your transformer is tapped, if your voltage is lets say 212 then transformer should be tapped for 208, the 1000 series machine were always like to be tapped lower on the transformers.
????? did you drop the keypad or is the cable damaged in any way....
So when you turn on the machine, nothing shows up on the keypad correct?
If you go thru the process of homing the machine, does it still hard home the machine, and if it does that can you use the directional keys and it still moves the machine.
Ok, the display is out. Unfortunately until Multicam starts accepting repairs again, your only alternative would be to buy a new or refurbished keypad.
I have the same problem on my 5000 series . It only shows (KDM20 V1.10SN=814. Can’t even move the machine any solutions
How old is your 5000?
