- Problem- MultiCam 3000 Xa servo drive motor
We have a problem with the Xa servo drive motor shuddering during movement and when we dismounted it, found the pinion gear to be worn. Does anyone have a contact for getting a replacement gear, servo motor, or entire drive unit? Our experience contacting MultiCam hasn't had a great response and our machine is down. Any help would be appreciated.
Re: MultiCam 3000 Xa servo drive motor
Does the gear spur have
22 teeth
22mm bore
If so I have them for 75.00 usd ea. while you are replacing them you should replace all of them at the same time. There are 3 total, before you take the old ones off, check the measurement of the old pinion, match the measurement when you install the new one.
Let me know if these are the ones you need.
correction to the post above
25 teeth
22 MM bore
That is exactly the ones I need! How may I contact you?
Give me a call...678-548-1483
Maurice
I normally ship Fedex the shipping cost ranges from 25 for ground, 55 for international priority.
What size and pitch are the pinions for the 3000 series???
shuddering motor could also be coming from an overheating control board. you could swap the connections in your electrical cabinet between the Xa & Xb and see if the shuddering follows the swap. Swollen capacitor or fried wires at connections of the control board would do this as well
- You may not post replies
- You may not edit your posts
Forum Rules
