how old is your machine
Hi guys,
This is my first post, i'm desesperated with a Multicam 1000 series M CNC router.
I´ve overwritten original firmware with trash (by error) and now cnc router doesn't work.
I don't have original 3 firmware files and i've looked for it with no luch. Maybe someone could release it?
I think 3 files may be something like J2_xxx.bin, h4std.uc & h4ldr.uc
Thanks in advance!
It's dated july 2006.
What i'n not really sure it's if board is J or K series. How can i know it?
are you without support (to, just like me right after the bill was settled :-((( )
anyway, long time ago, had lost of fun since with my MG204 ~2000
I ran into the same problem like you're havin' now when installing new firmware
the proces / program(motionmechanic) leave's lot's of room for mistakes
pretty sure my files will be to old for you, you can have them anyway, I don't need them any more :-)
I run it another controller, although the old one still works if you now where to kick . . .
let me/us now how you're getting on please
good luck
You're right kessfrees , the lack of support is very bad and always money ahead.
I appreciate sincerely if you can send me the files, I 'm not really sure it will be compatible but i have nothing to loose, now the controller is as usable as a rock.
With motionmechanich the only thing you can do is save NRAM with parameters of the machine (but not extract the firmware completely, i think) and send a firmware that you own (that three files in the same order) to flash.
That NRAM file is stored as .uc and contains something like this:
Version Information
**** MultiCam Inc. ****
** Router Machine S/N 1-101-R05240 **
Loader V6.70
Standard V6.70
MCIF V4.41a
uCITO V2.06c
Keypad KDM20 V1.22
Controller :
LC520 Rev 2 Interface M64 (ID 22)
Serial Num #2806
Speed 133MHz
Memory 8M
Step Delay ON
IP Address 192.168.1.79(255.255.240.0)
Bus Voltage 36.924 VDC
Module Information
MODULE INI_STD 2 6.70
MODULE INI_MD4 20 1.28
MODULE INI_INIT -3 6.70
MODULE INI_INVERTER 5 2.19
FIRMWARE 4.41a
SERIAL_NUM 2806
FEATURES 212797
MEMORY 3
MPU_MHZ 133
CONTROLLER_REV 2
CONTROLLER LC520
Machine Parameters
-145.787430 1 set_float
145.787384 2 set_float
[more memory positions]
Maybe the next option will be get another controller/driver, but first i'm gonna try all possible options.
I've sent you a PM
I've got your PM
can't sent email now, server is down
i'll keep trying
OK....I need to know what version of software that you have.
Exit jobserver
Find motion mechanic
if you have a gray screen, goto Tools and goto Terminal
at the >
Goto File and capture NVRAM
cut and paste what you see on the site, I think I might actually have the fimrware file.
The text i paste is copied directly from motionmechanic.
I think it might be useful.
Loader V6.70
Standard V6.70
MCIF V4.41a
uCITO V2.06c
Keypad KDM20 V1.22
Controller :
Serial Num #2806
Speed 133MHz
Memory 8M
Step Delay ON
Module Information
FIRMWARE 4.41a
SERIAL_NUM 2806
FEATURES 212797
MEMORY 3
MPU_MHZ 133
CONTROLLER_REV 2
CONTROLLER LC520
I actually have this file, if you would send me your email address. I can send it to you
Hello, are you fix it problem?
I have same problem on Multicam 1000 series M CNC router.
Firmware Overwritten.
I lost firmware on old hard bracked disk.
And i lost DBI file for correctly connect, i can't use Mechanical Service Tool
And now I am looking for the same files. Anybody can me help? Pls
Have you seen this thread ?
https://www.cnczone.com/forums/multi...d-looking.html
My machine is still running very fine !
Many thanks to MCP again :-)
Oh thank you, i try later. but do you have DBI file? Because Service Tools request this file for correct connection
Attachment 470788
Attachment 470790
This doesn't work unfortunately.
I don't know about a DBI file, there is one mention of it on his forum though :
https://www.cnczone.com/forums/comme...ml#post1172937
But I doubt if this will be any help to you.
If I my suggest, retrieve and post your'e machine specifications here, following these instructions :
https://www.cnczone.com/forums/multi...ml#post1657662
And for someone like MCP.
I make capture NVRAM with "MCP" instruction. And i have
****Router Machine S/N M2400****
Loader V6.70
Standard V6.70
MCIF V4.41a
uCITO V2.06c
Keypad KDM20 V1.20
Controller :
Serial Num #2400
Speed 133MHz
Memory 8M
Step Delay ON
IP Address 192.168.0.88(255.255.240.0)
Bus Voltage 36.178 VDC
Module Information
MODULE INI_SELFTEST 1 0.00
FIRMWARE 4.41a
SERIAL_NUM 2400
FEATURES 199485
MEMORY 3
MPU_MHZ 133
CONTROLLER_REV 2
CONTROLLER LC520
Also, I can not open the "Firmware Update" program.
Since it requires you to specify the "DBI_file.mdb" in the connection settings
Ok, i found my original machine parameters. But when i "store" i was not choose to "parameters". I not looked where it will be stored. I overwritte INIT user file in NVRAM. And now i need sample of "init file.uc. Anybody can sent self file? i will look what be need coded coded in this file.
I found the original parameters file.
And I received the "User Init" file from the Multicam service center in Russia
The machine is repaired, everything works!
