Thanks for the help guys!! much much appreciated!!! The machine is up and running. I only need to replace the racks and pinions!
Regards,
Ugan
Yup, those dont look like nice gears anymore. Greasing and cleaning them on a weekly basis will help, do you have dust extraction? I dont the the pinions and racks would make your encoders fail, the would make the the machine tolerance less precise however. If you humidity is high that means you will have less static electricity right? Im not sure if its a good idea to dehumidify as it might bring other problems.
Regards,
Ugan
Hi MCPService, i need the exact same servo as was mentioned above in this thread (3483-ME4697-F), do you still have the one in stock, cause I would buy it. Thanks for response
I am not in the office but I will be there on Friday. Post a pic of your motor so I can tell which one, you have. The motors are the same, just the connections face different ways.
Here are some photos of the servo
I have a multicm router pro series made in 1998 or a little later. The machine has a six station tool changer (rotary). I am looking for a wire schmatic for the machine. I bought the machine used 9 years ago and it just needs a little up-grade.
Can anybody help?
mcu
A pro series machine, hmmmm you have a older controller either a
m23/ either a j930,h971
and if you are lucky maybe a M24/H or K board.
My question to you would be:
What type of upgrade are you looking to do, if you are looking to upgrade your controller you might be better off finding another used machine, because a Multicam upgrade to a M2545 controller is easily over 10K, not including installation.
I've have got to look thru my old files, but I think I have a basis pro electrical schematic, send me your email address and if you have any other question give me a call.
678-548-1483
Chris
Does anyone still have one of these servo motor for sale ?
I have 5000 series down and looking for servo motor replacment.
Hola, soy nuevo en esto, tengo un cnc MULTICAM de 1996 y nesecitaria el software wdnc95, alguien podría ayudarme a conseguirlo, gracias
I have a MCG 3483-ME4697-R Motor that i need fixed or replaced any one know some one in Los angeles, email me or reply please 310 748 1110
Hi there! I am new to this site. Not sure if this is the way, but I am also encountering the same problem with the 3000 servo motor. I read you have some in stock, can you help? Please let me know, thank you !
[QUOTE=jcocina;2330264]Hi! I am also encountering the same problem with my multicam 3000. Do you have these servo motors?[/QUOTE
try this company
they have quick turnaround times
i am completely satisfied with repair
& response. also most companies
only give 6-12 mo. warranty
this co. gives 18 mo. warranty,
also if u have cheaper price
they will beat it by 10%.
Hello. My name is Mariano. I'm from Argentina. I have problems with my Multicam V Series plasma cutting machine. There is actually no technical support in Argentina. The installer of the machine is from Brazil and He can't help me. I started having problems with control... the display apparently changed the resolution. That way I lost the visualization of some cutting parameters. I tried to solve it but now the machine does not work. I need help and I don't know who to turn to. Thank you.
