Dear all , I would like a little help. I recently activated option Automatic Interpolation Preview Control (G05.1) & Bell shape acceleration/deceleration on a MORI SEIKI MV40E (year of manufacture 1999) machine with Fanuc 21i controller. In order for the function to perform best a number of parameters needs to be set correctly. Does anyone has a similar machine in order to help me? From what I know the parameters are the following:
#1770
#1771
#1783 (X/Y/Z/A)
#1785 (X/Y/Z/A)
#1731 (RAD R FOR FMAX)
#1730 (CIR RAD FMAX)
#1732 (CIR RAD CLAMP F)
#1422 (MAX CUT FEED RATE)
#1432 (MAX CUT FEED RATE X/Y/Z/A)
#1621 (RAPID T2 BELL X/Y/Z/A)
#1784
#1785
#1768
If there are others that should be adjusted too please add. I strongly believe that the correct parameters' value are related to machine mechanical structure & parts so I do not think just imputing values from different kind of machines makes sense.
