Need Help! SV-503/40 alarm 410 z-axis
Results 1 to 2 of 2
Thread: SV-503/40 alarm 410 z-axis
    Apr 2007
    Default SV-503/40 alarm 410 z-axis
    The machine is a SV-503/40 with fanuc 18i-m model a
    The alarm 410 for z-axis will randomly pop up when I unlock the door or m30 is commanded in a program and the z-axis brake is engaged.
    I increased parameter 1829 value a few hundred after observing what the value at DGN was hitting and that seemed to help a lot.
    fanuc troubleshooting manual says to check DGN G126 bits 0-7 for '1' when axis is clamped and i get only zeros
    can I just increase the parameter 1829 value until this problem goes away without any undesirable side effects? are there any common issues i can check or should i just follow the trouble shooting flowchart?
    Mar 2008
    SGP
    Default Re: SV-503/40 alarm 410 z-axis
    probably the brake or timing belt issue.
