- Need Help!- mori seiki mapps msg 501 program edit!!!
Hello engineers. PLZ HELP!!!
We have a Mori Siki nv5000 machine with controller fanuc 18i - mapps msg-501.
When we want to edit or add a program. system say error "EDITION IMPOSS"
PANEL key-switch in edit position and screen in edit mode .
Does anyone have a mapps operation manual or mapps parameters manual?
Re: mori seiki mapps msg 501 program edit!!!
Are you still having this problem? Do you get any alarm number prior to the message.....ie EXnnnn code before the message?
Hello Antipak,
Do you have on the controler a button with GOP PARAM ?
If you have it push it and on the screen there will be a key above PROGRAMM / OFFSET / PARAM MAKRO
Push the buttom PROGRAMM and the key needs to go OFF.
Hope I could help.
Grtz Tom
- You may not post replies
- You may not edit your posts
Forum Rules
