Mori mv35/40 yasnac mx1 startup problem
Results 1 to 6 of 6
Thread: Mori mv35/40 yasnac mx1 startup problem
    Apr 2015
    Default Mori mv35/40 yasnac mx1 startup problem
    Was setting tool offsets and machine shut off. Tried to restart and the crt flashes yasnac for a split second and goes away. Crt still powered and second push, to power the servos does nothing. Fuses all good. DC power supply putting out 5,12,15 and 24vdc. NVM contactor picks up but not the SVM contactor.
    I think it might be the servo control board, jancb-cp01. Any idea what the differences are between the cp01 & cp01b boards? What about the different board revisions, are they interchangeable?
    . Anyone out there been through this nightmare?
    Thank you all for your time
    Apr 2015
    Default Re: Mori mv35/40 yasnac mx1 startup problem
    I also saw in another post a mv35/40 with a jancd-cp03 or jancd-cp03b, board or boards.
    I've unplugged every input that I can think of, that will still let me operate the power button. Everything except the "M" & "J" Honda plug on the jancd-cp01b board. Still no "svm" contactor (located on the jancd-tu01/jznc-tu04 board combination) pull in or continuation of the startup sequence.
    I'm suspicious of the jancd-tu01 board because near as I can tell, from the obsolete component data sheets that i can find, the bridge rectifier "sv1b10" and 5v regulator "uPc7805h" are putting out 14vdc originating from transformer "DE8401368".
    Can anyone verify for me the voltage input, pin F5 & F6 and voltage output, pin F1 & F2 with (1) their machine breaker ON, NOT powered up (2) 1 power button push, controller powered up and then (3) 2nd power button push, both controller and servos powered up? These pins, F1,F2,F5 and F6 are from the transformer "DE8401368" on the jancd-tu01 board, located on the jznc-tu04 servo power supply board. Yeah there's a lot going on with the servo power supply board! PLEASE BE CAREFUL .. Those pins, F5 & F6 on my board have 240V between them and F1 & F2 are 40V, which are in a fairly tight confined space.
    These servo power supplies were in Mori lathes & mills as well as other manufactures lathes and mills. The common denominator being the "DE8401368" transformer & jancd-tu01 board. Note .. The transformer was mounted under the jancd-tu01 board on the lathes or machines with remote cabinets.
    My next moves ..
    - Make a schematic of jancd-tu01 board and understand the function and direction of the (5) 4 pole, double throw nc/no relays.
    - Disconnect DC loads and try powering up.
    - Chase traces and test components on jancd-cp01b board, connected to the "M & J" Honda connectors coming from the boards and power button mounted in the control panel assembly.
    Even if no one replies to these threads maybe in the future this information can help someone who's in the same situation I'm in now. I've subscribed to all the threads i can find on practical machinist, cnczone and industryarena regarding anything related to startup problems. I have been repeatedly frustrated by members who have machine problems and get help, then only to never return with information on what fixed their problem. From members like Wayne, who has loads of valuable Mori information that could or will be lost forever, or underthetire. Both of which have given their help tirelessly in the past.
    I can only strive to set a better example.
    Thank you for your time.
    Apr 2015
    I've made progress on my problem. I did a memory regeneration and re entered all the parameters and am getting closer. Updated information here ... Well it won't let me post the link so search practical machinist dot com for
    "mori seiki sl-2 no-power to nc"
    Member MEOM1705's Avatar
    May 2022
    did you find the solution to the problem i have the same problem the control does not turn on the SVM contactor does not turn on best regards
    Apr 2015
    Quote Originally Posted by MEOM1705 View Post
    I did .. I'll have to look through my notes tonite and see what the solution was .. It was several problems ago now.
    I'll return here and post my fix.
    Apr 2015
    Quote Originally Posted by dll6 View Post
    So at the time I was still getting all the parameters back into the control after wiping the memory. When I wiped the memory I didn't know that many of the parameters were hidden and could only be seen with the system switch in position 4. Once I got that parameter information from Mori Japan my machine powered up correctly.
