Mori Seiki TV-30 or 300 backup needed - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 23 of 23
Thread: Mori Seiki TV-30 or 300 backup needed
  1. #13
    Jan 2013
    Default Re: Mori Seiki TV-30 or 300 backup needed
    Thanks for the parameters Mike. I loaded them up, and I also addressed the low lube alarm. There's no more alarms, yet it still wouldn't do a tool change. Then I noticed there was a stop code, T03 Block Stop 0301, which in the manual says Single Block Mode is on. So I tried pressing the cycle start button multiple times, and step by step it did the tool change! That tool change arm was scary fast, so I slowed the rapid on that sucker down. So I started digging into the ladder, and found that the Single Block mode is output Y21A in the ladder, and among the inputs is device X13B which was permanently stuck on. I then forced device X13B to a zero bit via the PLC I/F screen, and tried to run the tool change in MDI mode again. The tool change proceeded as expected without having to hit the cycle start multiple times. So now I just have to track down what device X13B is and I should be set. I don't have a wiring a diagram so I'll be reaching out to Mori to find out what it is.
  2. #14
    Jan 2013
    Here's an update in case someone else runs into this with the MSC-802m control, the stuck Single Block Mode was caused by corrupt GOP memory. A fellow TV-30 owner provided the procedure to reset the memory and all was resolved.
  3. #15
    Mar 2013
    Việt Nam
    I have the same problem. Can you do my favour?
  4. #16
    Mar 2013
    Việt Nam
    Dear all! Can Anybody help me?
  5. #17
    Oct 2008
    Israel
    Quote Originally Posted by krisxone View Post
    Hi krisxone,
    I have a TV-400 with the same single block problem.
    Could you please share the GOP memory rest procedure?
    Would appreciate it.
  6. #18
    May 2015
    united states
    I have a tv-400 and am in desperate need of parameters anhyone help please?
  7. #19
    Feb 2014
    Anyone know how to get rid of the "Z70 ABS. Illegal 0001 1” My battery died and I lost all absolute positions. I figured out how to set X,Y and Z but still I got the "Z70 ABS. Illegal 0001 1”. My guess is the 20 tool changer that lost its zero position.
    I found loads of how to´s for adjustment of zero return positions for ATC arm, but when I select C-axis and try to use the jog wheel to rotate the tool changer arm “M01 Operation error 0106” appears in the screen and I can´t move the arm.
    The error message for “M01 Operation error 0106:
    “HNDL FD NOW (Handle feed axis No. illegal) An axis not found in the specifications was designated for handle feed or the handle feed axis was not selected.”
    Anyone knows aynting about above?
  8. #20
    Nov 2013
    Hello,
    We have similar problem but we solved the ref point of ATC on ours TV-400 with 802M (Meldas M50). But we lost the tool change program for drum ATC with 12 tools. So if anybody have tool change program please HELP... Many thanks in advance
    To move the drum via handwheel u need to set Z axis in top position (ref no.2). Then u need to press and release STOP/FEEDHOLD PROGRAM and STOP SPINDLE button until u got flashing STOP/FEEDHOLD PROGRAM LAMP (now that can be the tricky part) usually i go in LADDER MONITOR and see merker M711 - ADJUST MODE ON it should be ON when u do the right combination of that two button... Then u need to set the parameter 6440 bit 2 to 1 that is to activate ATC to handweel.. If u have axis interlock signal u can set them on via PLC I/F ---- Y1BB 1 2 and Y1C3 1 2 ...
    Then when u get to moving drum via handwheel u need to go to servo ABS and do the proceudure like u did with X or Y or Z... (set drum in right position and then REG. INIT. to 1 and ORIGINE to 1 and then u move drum in - (negative direction) until u got OK on screen...
  9. #21
    Nov 2013
    Hello,
    If anybody have tool change program for TV-400 with MSC-802M (MELDAS M50) please post it or PM me...
    Many thanks in advance...
  10. #22
    Dec 2016
    Ecuador
    Hello,
    Anyone who has a Mori Seiki TV400 machine, Could you confirm me if the connection diagram is correct?. Thanks
    Attached Thumbnails Attached Thumbnails Mori Seiki TV-30 or 300 backup needed-image007-jpg
  11. #23
    Nov 2013
    Quote Originally Posted by sandinotg View Post
    Hello,
    Hello..
    This is my diagram of TV400 and cabinet... And the last one on my scheme is SPINDLE DRIVE (u can recognize it because of spindle FAN)D1 D2 D3 are X Y Z and D4 is for ATC (automatic tool change) and C5 in my case is for APC arm (automatic pallet change and it is a PLC axis C5 ) the last is the spindle drive and it is D6 (in scheme is Unit5)
    Best regards..
  12. #24
    Nov 2013
    Hello,
    Hello..
    Best regards..
    Attached Thumbnails Attached Thumbnails Mori Seiki TV-30 or 300 backup needed-scheme-jpg   Mori Seiki TV-30 or 300 backup needed-cabinet-jpg
