- MORI SEIKI MT2000 UPPER HEAD X POSITION OFF ON ANGLE HOLES
Does anybody know how or if there is a way to fix:
When I drill a hole at an angle, the position is way off.(Like .100 to .300 off) I have to put in a large offset to bring the hole to the correct position. Is there a parameter or an alignment procedure I am missing? I don't have any issues with position on holes @ B-90. or B0. Its just when the B-axis is anywhere in between, example B-45. or B-60.
I know about Parameters D452, D456, D460, & D464, but not sure if I'm checking them the correct way. If there is an official Mori Seiki DMG Alignment Procedure to verify the way I'm doing it is correct.
Please help!!
Thanks,
TNTJerseys
- You may not post replies
- You may not edit your posts
Forum Rules
