DMG Mori DMU75 Monoblock Current Monitoring (Need Help)
Results 1 to 4 of 4
Thread: DMG Mori DMU75 Monoblock Current Monitoring (Need Help)
    Member cncbachelorstudent's Avatar
    Apr 2021
    Question DMG Mori DMU75 Monoblock Current Monitoring (Need Help)
    Hello,
    I am Kerim, a bachelor student that is trying to acquire data from a CNC machine of which the model is DMG Mori DMU75 Monoblock. We are currently working on a project which needs current (electricity) data of servo motors of the CNC. However, we do not know how to transfer this data on a PC environment. Is there anyone who knows how to transfer current data (in terms of Amperes) to a PC? Thank you already for anyone's effort.
    Dec 2013
    Default Re: DMG Mori DMU75 Monoblock Current Monitoring (Need Help)
    The best way to do this is using non-invasive current transformers. There are all kinds of devices available, Google 'power monitoring' . Here is one way to do it, maybe a good starting point. https://learn.openenergymonitor.org/...energy-monitor
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2021
    Thank you very much for you help! After building this circuit, where can I put this device to monitor the current? Thanks in advance.
    Dec 2013
    You would run the motor power wires through the current transformers.
    There also may be a way to read the individual drive current directly from the drives using the ModBus or whatever protocol that system uses, you would need to look at the drive documentation for more information.
    Jim Dawson
    Sandy, Oregon, USA
    CNCFr's Avatar
    Sep 2002
    Timbuktu
    Which controller is used with your machine?
