Originally Posted by
jaherrera3499
1) Go into "Field Adjustment". Hold down "Feed Hold" button while turning Panel Edit key On (all the way to right) then back to middle position.
2) Push "Setting" key.
3) Type "95" then push "Input" key.
4) Make sure you are in the "D" parameters. If not, push soft key for "D".
5) Change "D" parameter 148.5 and 149.6 to 1 to enter "Turret Adjustment" mode.
6) You can now use the turret + and - keys to clamp/unclamp turret. + for unclamp, -for clamp. You should be able to hear turret unclamp/clamp.
7) Now use selector switch for the axis' to select "T" axis (may be X2 axis). It should be flashing. Make sure turret is unclamped and rotate using MPG to tool position 1. Clamp and unclamp to check for smooth operation. If you need to, use an indicator in tool pocket.
8) After tool position 1 is established and turret is clamped, turn PWE on and toggle 1815.4 for turret from 1 to 0 then 1 again (Should be the 3rd axis). It will ask you to power off after you change it to 0, but don't. Go back and change to 1, then power off.
9) Power back on, perform a turret index. It should be fine then. Now you can check for a damaged belt or a damaged speed sensor.
