NEED HELP! RE-ZERO TURRET SERVO FOR SL 150
Results 1 to 2 of 2
Thread: NEED HELP! RE-ZERO TURRET SERVO FOR SL 150
    Member torresandrew687's Avatar
    Apr 2022
    Exclamation NEED HELP! RE-ZERO TURRET SERVO FOR SL 150
    Mori Seiki has not contacted us about our issue regarding fixing the index on our turret. Our company has a manual that is intended to guide us to re-zero our turret servo for a Mori Seiki SL-150 lathe. The instructions call out for us to enable "Field Adjusting Mode", which is prompted by pushing the 'feed hold button' and turning the 'edit key'. The issue is that we are unsure which button is the 'feed hold button' as it is not labeled or displayed as that on our control panel. If anyone has any information on if this is an alias for a different button, if this mode does not apply to our model, or if there are any other instructions to re-zero our turret servo, please reply!
    Member tristarcnc's Avatar
    May 2017
    Default Re: NEED HELP! RE-ZERO TURRET SERVO FOR SL 150
    Quote Originally Posted by torresandrew687 View Post
    Red button and could also be labeled as cycle stop.
