After a month of working on a dead Mori Seiki SL 3H with Fanuc 10TF , I finally got it running. I bought it defective so no high expectation where there. I had to buy 2 defective memory boards and replace the cnc power supply. After I reentered the parameters it came back to life but no PC data was available, so had to extract some of it form the ladder diagram to get the tool turret rotating correctly. That's all I can do.
The machine came with the optional Q-Setter. It requires pc data that I don't have to get it working. The machine clearly sees it when I move it down because the rapids and jog are canceled and only handwheel movement of the axis is permitted. But no value is registered in the offset table after contacting the probe. All parameters for it are ok but I am missing the pc data for it.
Quite impressed with this old banger. It holds close tolerances quite well. Only issue is that it is very noise especially in lower gear.
Any help regarding the Q-Setter would be greatly appreciated.
