Originally Posted by
macgyver37
Haven't checked in in awhile... I don't have exact numbers on hand at this moment, but it is powered from the same transformer as the PO had it on when I bought it. I got to test drive it at his place and everything worked as it should. I checked the voltages going in the transformer and going out, wrote them down and matched it at my place. The lathe is setup on 480v, I have 240v 3 phase at my place, not 208, and from what I recall it is within a couple percent of the same voltage as it was at his place. Rotation is correct as the hydraulic pump and chip conveyor are correct rotation.
I have not had a chance to get back to it, I have been buried with work and just haven't made any progress on it. I will try to remember to find my notes on it and also investigate inside the cabinet more, see if there is anything that looks like it may show what range it should be in.
