hi all
we got a bran new DMG Mori NLX2500 with y axis also
so when i do a regualr milling contour with regular endmill on any odd shape it works perfect so our cam system post is spitting out the blow
and when i do with the same path 90deg chamfer tool
the chamfer tool always few degrees off from the outline of the contour..
here is my Gcode for both, i coudnt see anything that would through the chamfer offcenter
and do I need to use G17 at all? as i fail to understand why this machine would need g17 and g18 and g19 since everything is controlled by cycle?
but you guys might spot something..
so can anyone see if there is some gcode mssing? or maybe its machine resetting the c axis after every tool?
anyone can spot any problems with gcode?
regards.
