Need Help! Mori Seiki CL203 - problem with turret zero point
Results 1 to 5 of 5
Thread: Mori Seiki CL203 - problem with turret zero point
    Member dornbush's Avatar
    May 2020
    Default Mori Seiki CL203 - problem with turret zero point
    Hello everybody!
    Today my machinist hit the chuck with the turret. After that lathe shows EX4042 alarm - “turret need zero return”.
    Zero positioning is not working through the MDI mode. Can anyone send the procedure for turret zeroing for this lathe, or any similar?
    Lathe has Mitsubishi Meldas MSG803 cnc control.
    Thanks in advance for your help!
    Aug 2007
    Thailand
    Default Re: Mori Seiki CL203 - problem with turret zero point
    Hi
    Do you have backup all parameter of this machine?
    Can you share me .
    Member tristarcnc's Avatar
    May 2017
    Quote Originally Posted by dornbush View Post
    Hello everybody!
    Where you able to reset your zero return yet? I found a procedure in our files and if you send me a message, I will scan and email it to you.
    Member amirnili's Avatar
    Apr 2023
    Quote Originally Posted by CNCTECHNOLOGY View Post
    Hi
    Can you share me .
    hello
    Do you have backup now?
    im want backup of parameters and pmc.
    could you share me?
    Member cnctech1967's Avatar
    Jul 2021
    Quote Originally Posted by amirnili View Post
    hello
    could you share me?
    I’ve backup CL203 with Mitsubishi controller MSG-803
    Member sting007's Avatar
    Feb 2015
    Quote Originally Posted by tristarcnc View Post
    I need the procedure please
  7. #7
    May 2020
    Quote Originally Posted by sting007 View Post
    Hi, you can send me your email so that I could send you pdf
