I can go into the operation panel and set ZERO POINT ADJUSTMENT to "VALID"
I can move all the axis using the thumbwheel, but I cannot ZERO the axis via the front panel buttons
Whats the correct procedure?
The manual says to perform a zero return after an M70 error, but no mention of this above error.
I have tried to follow the procedure to zero the axis via the SYSTEM - NC SYSTEM - MENU - ABS SRV, but the ABS SRV options does not appear after I press MENU.
