Need Help! How to enable ethernet and set IP Address on SL-204 with MAPPS MSG-805
Results 1 to 1 of 1
Thread: How to enable ethernet and set IP Address on SL-204 with MAPPS MSG-805
    Registered bbeallo12's Avatar
    Nov 2018
    Default How to enable ethernet and set IP Address on SL-204 with MAPPS MSG-805
    According to the "Caps-Server Instruction Manual" (WIN-CAPSSERVER-A0E) which states it's applicable with the MSG-805, there should be a soft key option called "COM SET" for setting the IP Address.
    Our other Mori Seiki CNCs did have this option, but for some reason this machine doesn't have it.
    Is there another parameter somewhere that needs to be changed to enable the ethernet menu?
    Thanks.
    Jun 2016
    Slovenia
    Default Re: How to enable ethernet and set IP Address on SL-204 with MAPPS MSG-805
    HI,
    I have the same problem on the same machine. Is there anyone who knows the solution, which parameter enables the network option?
    We have checked, and we have the Ethernet port...
    Regards.
