Control 810D Siemen cnc Machine VMC how to set offset spindle Orientation position
Results 1 to 2 of 2
Thread: Control 810D Siemen cnc Machine VMC how to set offset spindle Orientation position
    Registered RanaAli's Avatar
    Jan 2014
    Default Control 810D Siemen cnc Machine VMC how to set offset spindle Orientation position
    Hi Every One
    During tool change spindle is not at basic orientation position the deference is approximately 120 degree
    How can fixed the position or error
    any idea
    Thamks in advance
    Rana Ali
    Jun 2017
    United Kingdom
    Default Re: Control 810D Siemen cnc Machine VMC how to set offset spindle Orientation posi
    Go into CNC ISO page, MENU SELECT - STARTUP/SETUP - SET PASSWORD (SUNRISE) - MACHINE DATA - AXIS MACHINE DATA / AXIS MD (select spindle using vertical AXIS + / AXIS - keys), search for 34090(0) and add / subtract offset to figure already in there working on 0 as a minimum, 360 as a maximum), press input then vertical key SET MD ACTIVE. Power down, re reference, check spindle orientation, adjust and repeat until it's right.
