Problem Mori Seiki SL1 Yasnac LX2
Results 1 to 9 of 9
Thread: Mori Seiki SL1 Yasnac LX2
    Dec 2013
    Angry Mori Seiki SL1 Yasnac LX2
    Problem started with the display would not advance. Program running position display or any of the display buttons would not function until program stop command.
    LX2 was sent to Yaskawa for repair. It came back with the same problem. Sent it back, it returned with no crt display. Sent it back, it returned with the position display at every .328 of motion the display will jump .328 positive, continue to move axis same direction and it will jump .328 negative. Yaskawa cannot see the problem at there test and repair department. But they did program the control new eproms. The axes do not physically jump, and it is X and Z which act the same. The problem is present with pulse handle, manual jog buttons and in MDI. Does anyone have an SL1 that I could send boards to, in order to isolate the problem? Any address would be appreciated.
    Thanks Rick
    Feb 2009
    Default Re: Mori Seiki SL1 Yasnac LX2
    Let me get this correct. If you move an axis, it simply goes the wrong way, or is the axis physically jumping?
    Dec 2013
    Axes move in correct direction and they do not jump. Only the display jumps at .328 it will add and then subtract travelling in the same direction.
    Jan 2015
    Are you still struggling with this? Let me know I have an idea for you.
    Bob
    Dec 2013
    Thanks for the reply Bob
    Yes, machine is down, Yaskawa has been no help. Looking for a cp4 board to test with. Please any idea would help.
    Rick
    Quote Originally Posted by ncbobbys View Post
    Than
    Bob
    Jan 2015
    Rick... check the board and see if is a CP04 or CP04B
    email me : simplersys@gmail.com
  7. #7
    Feb 2014
    Hello
    I have a SL-1A with yasnac control,
    Do you still troubleshooting the control? there must be somthing to compare between lathes.
    I am also dealing with a issue in automatic mode
    let me know what happen with your lathe
    Regards
  8. #8
    Jul 2007
    Good Morning, by any chance do you have the electrical diagram for your Mori Seiki SL-1? I am willing to pay for a copy of it.
  9. #9
    Jul 2007
    Quote Originally Posted by Franco1 View Post
    Hello
    Regards
    Email masamayoa@hotmail.com
