Need Help! Mori Seiki Zl 15 SM lathe data transfer
Results 1 to 9 of 9
Thread: Mori Seiki Zl 15 SM lathe data transfer
    Apr 2014
    Default Mori Seiki Zl 15 SM lathe data transfer
    Hello,
    I recently bought an old Mori Seiki ZL-15 SM lathe from 1990 (2 spindled, C axis on main spindle), FANUC MF-D4 (I believe it's 0T series), I managed to start it (without the C axis since I cannot find suitable live toolholders) and now it's producing. The problem I have it's that I cannot send/receive data using the RS232 connection and the lathe will not accept parametric programming (#1=50 #2=12 etc), for this reason I'm loosing a lot of time writing programs by hand.
    Anyone can please help?
    Jan 2004
    Default Re: Mori Seiki Zl 15 SM lathe data transfer
    Just wondering if you resolved your data transfer issue ??
    Gunner
    Apr 2014
    Not yet
    Oct 2013
    Post Re: Mori Seiki Zl 15 SM lathe data transfer
    do you check your RS232 setting in parameters?i think this may be fault of your setting.tell me that do you have checked it?
    Feb 2009
    Probably a 0TT nightmare control. You will need Fanuc option custom macro for the variables.
    Gold Member
    Aug 2011
    Fordaville
    basic rs232 info for 0T is here.....
    Machinery RS232 communications settings for CNC controls including fanuc and mitsubishi
    check your parameters and cable. it really isn't that difficult to make it work as long as your machine and communication hardware is working.
  7. #7
    Apr 2014
    All, thank you, managed to solve the data transfer issue!
    Still -I know it is off topic- I could not solve the parametric programming issue, so any input is more than apreciated
  8. #8
    Gold Member
    Aug 2011
    Fordaville
    you need macro B. Its an option.
  9. #9
    Member Numees's Avatar
    Mar 2019
    If you still have ms zl 15 sm,please contakt me.
