Quick update. I have finished most of the wiring and was able to successfully test all 3 axis. I still have to wire the emergency stop and the axis limit switches. Whenever I get that done I should be able to post a test video! Here are some pictures of the wiring setup.
I had to wire the main power supply on the far side of the machine and run the power wires along the back.
I was able to 3D print some cable management brackets so that was fun.
I tried to wire everything so nothing touched the heat sinks but it was a tight fit. I guess I will just have to wait and see how hot they get and figure out a different placement if the wires are in danger of getting melted.
I 3D printed these rectangular mounting brackets for the breakout board and the ESS that worked out really well. Hopefully my next post will be a 3 axis movement test!
