- Mitsubishi M70V tool compensation wiew problem?
Why the M70V does not show tool offset positions.It does not display tool offset positions despite the value set in the parameter.
"It is possible to set whether to consider the tool length and diameter compensation using
parameter "#1287 ext23/bit4"."
But not show in "progam position window"
Only displays values when running an automatic program.
But if the machine is stationary then not.
This way I can't measure the tools by hand.
- You may not post replies
- You may not edit your posts
Forum Rules
