Error Z70 tx8h Traub
Results 1 to 3 of 3
Thread: Error Z70 tx8h Traub
    Feb 2018
    Default Error Z70 tx8h Traub
    Hello. How to remove the Z70 error in controlling the traub tx8h lathe. I have blocked 2 Z Axes.
    Attached Thumbnails Attached Thumbnails Error Z70 tx8h Traub-img_20180713_050644-jpg
    Sep 2017
    Bahrain
    Default Re: Error Z70 tx8h Traub
    Seems like the home position is lost?
    If its an absolute system, check the battery voltage on drive unit.
    If incremental, please do the initial referencing of all axis
    Feb 2018
    Already the error has been removed. I have a problem with spindle S1.G1 for mm / U does not work, and the C axis does not turn on. I need parameters for S1. I think there is a bug there. Simodrive 611 drive. Can anyone help?
    Member Alberto9016's Avatar
    May 2019
    error de drive axis
