Clear the memory with blue switch on CPU but do you have parameters backup?
hello guys, it turns out that my backup battery died, change the battery but my aki seiki meldas 64s machine does not start the system ready, with the black screen and only a small cursor flashes, I can not do any procedure because the control does not respond, Any suggestions?
PLease confirm the 7 seg LED status on the
1) NC unit
2) On all drive units
3) If you have replaced the battery how much is the voltage now on load ?
Turn the machine off and rotate the blue rotary switch on CPU from "0" to "7",turn the machine on again,wait about 1 minute until the 7 segmens display "Y",turn the machine off again,rotate the blue rotary switch back to "0",turn the machine on
The machine will boot again
Set parameter #1043 from "0" to "1",the machine display will be in english,
Good Luck!
hi victor, do you have an email where i can contact you, i'm from mexico too, i have the same problem!
