Need Help! harbor freight mini lathe wiring problem 7x10
Results 1 to 3 of 3
Thread: harbor freight mini lathe wiring problem 7x10
    Member Robcel1353's Avatar
    Jun 2021
    Question harbor freight mini lathe wiring problem 7x10
    Hello, I was given a harbor freight mini lathe being told the mother bored is bad.
    I checked the motherboard and all the switches for bad soldering ,burn components. took the mosfets off checked them. everything looked fine.
    but i bought a new bored and all new switches anyway. i wired them up the same way i got the lathe and still nothing. the red light on the on/off switch lights up but nothing moves the 1 and 2 terminals on the board show zero volts even when the switch is on and the nob is turned.
    maybe it was wired wrong from the last owner ? i cant find a good diagram that fit this bored perfectly.
    thank you
    Attached Thumbnails Attached Thumbnails harbor freight mini lathe wiring problem 7x10-20210622_145838-jpg   harbor freight mini lathe wiring problem 7x10-20210622_164710-jpg
    Member machinehop5's Avatar
    Aug 2009
    Default Re: harbor freight mini lathe wiring problem 7x10
    ...is this your machine? on the last page is a wiring diagram
    Attached Files Attached Files
    Jun 2021
    thank you
