Hello guys,
I'm going to purchase a Chinese WM210v mini lathe. My main focus with this lathe is to produce HTD5 pulleys made out from Aluminium 6061.
I would like to convert this machine to work as CNC, adding Nema23 motors to the X and Y axis. Controlling the the lathe motor, including the X and Y axis, will be done with TB6600 or DQ542MA.
I have few questions about the conversation process.
1. This is the lathe motor (850w) - Aliexpress. If I'll connect the marked connector wires to a stepper controller, do you think it will work and I'll have the ability to control the motor steps?
2. As for the X and Y axis , does anyone have any experience with doing so?
http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
