Build Thread HF 8x14 linear rail conversion....and maybe more... - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 72
Thread: HF 8x14 linear rail conversion....and maybe more...
  1. #21
    Default Re: HF 8x14 linear rail conversion....and maybe more...
    This is one of those threads I've beren following and looking forward to seeing it run. While not as long in running as the Z2 thread its been a long time coming. Nice to see some progress.
    Uuum... where is the turret?
    Bob La Londe
    http://www.YumaBassMan.com
  2. #22
    Jan 2016
    The lettering on the toolholders looks really nice. What method did you use?
    Cool project!
  3. #23
    Member CS900's Avatar
    Aug 2006
    Quote Originally Posted by Bob La Londe View Post
    You better believe i have one all designed up and ready to make. Haha. I'm excited to see it run too. My original conversion worked fairly well, and while I'm loosing a bit of diameter turning capacity, i think the rails will stiffen things up quite a bit. And to answer the next question everyone will ask, my max diameter I can chuck now is around 3" before it'll hit the table. not super great, but very rarely do i turn anything over 2".
    Quote Originally Posted by burbingus View Post
    Cool project!
    Thanks, they are just engraved on a CNC, filled with nail polish, and sanded down.
  4. #24
    Aug 2006
    Got a little more done on the lathe today. Tail stock is all mounted up.
    HF 8x14 linear rail conversion....and maybe more...-20200223_163738-jpg
    HF 8x14 linear rail conversion....and maybe more...-20200223_163746-jpg
    In addition to having to make a new base that will work with the linear rails, the ball screw goes right down the center of the base casting so the original screw and locking clamp would no longer work. So i made a steel version that goes around the ballscrew. It's kind of hard to see, but here's a cross section view of how the new locking clamp looks.
    HF 8x14 linear rail conversion....and maybe more...-cross-section-jpg
    Attached Thumbnails Attached Thumbnails HF 8x14 linear rail conversion....and maybe more...-20200223_163738-jpg   HF 8x14 linear rail conversion....and maybe more...-20200223_163746-jpg   HF 8x14 linear rail conversion....and maybe more...-cross-section-jpg
  5. #25
    Aug 2006
    Squared up the axis today. I clamped my granite square to the "master" Z rail and swept and indicator on it. Maybe a little ghetto of a set-up but it's not stupid if it works! You can also see the new tailstock clamp at the tail end.
    HF 8x14 linear rail conversion....and maybe more...-20200229_125348-jpg
    square to within .0002 over 6" not too shabby.
    HF 8x14 linear rail conversion....and maybe more...-20200229_130843-jpg
    Attached Thumbnails Attached Thumbnails HF 8x14 linear rail conversion....and maybe more...-20200229_125348-jpg   HF 8x14 linear rail conversion....and maybe more...-20200229_130843-jpg
  6. #26
    Jan 2013
    us
    what spindle motor will you be using?
  7. #27
    Aug 2006
    Quote Originally Posted by toddbeau View Post
    right now i'm going to reuse the motor i had which is a 1/2 HP ac motor with a VFD drive. Ultimately i'd love to have an AC servo so i can do positioning and rigid tapping.
  8. #28
    Aug 2006
    Apocalypse Update!
    Motor is mounted, but still needs to be wired up again. Took a while to get the motor in alignment, but it turned out well. I used some string for alignment and to size the belt.
    HF 8x14 linear rail conversion....and maybe more...-20200322_120914-jpg
    right now the weight of the motor tensions the belt. If i have any problems with belt slipping, I'll add an adjusting screw. Don't mind the extra long bolts, they are temporary.
    HF 8x14 linear rail conversion....and maybe more...-20200322_123703-jpg
    Starting to look like a real lathe again...
    HF 8x14 linear rail conversion....and maybe more...-20200329_104131-jpg
    HF 8x14 linear rail conversion....and maybe more...-20200329_104113-jpg
    Also, a bit less fun, I got some wiring done to the point where I can jog the machine around. While I can't use the encoders for position feedback. I made an adapter cable and used the DRO on my lathe to read the encoder output. Little ghetto, but it worked great. I got the step/inch tuned in and adjusted my backlash to under .0005 for both axis. And for those interested my current motor settings are 150 IPM with an acceleration of 40, and I think there's still room to go higher on both.
    HF 8x14 linear rail conversion....and maybe more...-20200329_104207-jpg
    still need to wire in the new limit switches and rewire the motor VFD and I think I'll be ready for some test cuts.
    Attached Thumbnails Attached Thumbnails HF 8x14 linear rail conversion....and maybe more...-20200322_120914-jpg   HF 8x14 linear rail conversion....and maybe more...-20200322_123703-jpg   HF 8x14 linear rail conversion....and maybe more...-20200329_104131-jpg   HF 8x14 linear rail conversion....and maybe more...-20200329_104113-jpg
  9. #29
    Jan 2013
    us
    Thanks for the updates, I'm planning on converting mine. Are you planning flood/mist cooling?
  10. #30
    Aug 2006
    probably mist for now. I'd like to get a flood system set-up for the mill and the lathe eventually though.
  11. #31
    Feb 2012
    I'm working on converting an old Jet turret lathe. It's similar in swing and bed length, but a lot beefier. You do some nice work! Really making me want to get mine in the mill to cut proper rail mounting surfaces, with shoulders like yours.
  12. #32
    Aug 2006
    So did my most favorite thing today....wiring....got the spindle wired up and the new limit switches working.
    The Z axis limit switch is mounted directly to the tailstock. That way no matter where the tailstock is on the table, the saddle will never go careening into it.
    HF 8x14 linear rail conversion....and maybe more...-20200404_173641-jpg
    The X axis has a high precision switch repeatable to within .0002. Should make it so once my X tool offests are set i'll only ever have to touch off the Z axis to set my part origin. i'm looking forward to that!
    HF 8x14 linear rail conversion....and maybe more...-20200404_173650-jpg
    I also plugged all the unused holes in the table so as to keep coolant and chips out of the ballscrew.
    HF 8x14 linear rail conversion....and maybe more...-20200404_173508-jpg
    and lastly first cuts were made!! It was just done joggin the machine manually, but it cut like butter.
    HF 8x14 linear rail conversion....and maybe more...-20200404_173521-jpg
    Attached Thumbnails Attached Thumbnails HF 8x14 linear rail conversion....and maybe more...-20200404_173641-jpg   HF 8x14 linear rail conversion....and maybe more...-20200404_173650-jpg   HF 8x14 linear rail conversion....and maybe more...-20200404_173508-jpg   HF 8x14 linear rail conversion....and maybe more...-20200404_173521-jpg
  13. #33
    Member bill south's Avatar
    Apr 2005
    CS900;
    Are you winging this build or do you have a set of conversion plans? I have a Travers Tool 9 X (something) and have toyed with the idea of conversion but just haven't committed as of this date. I always look at conversion threads for ideas and do like your handling of the ball screw installations. Linear rails will most definitely be the way to go and I just happen to have some of the parts on the shelf from an old RF45 conversion. Anyway, thanks for posting your build. Looks like a fun conversion.
    Have a good day and stay safe.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  14. #34
    Jan 2013
    us
    Very nice work for sure. What size steppers are you using? Also if you could share details on your limit switches I would appreciate that.
    Todd
  15. #35
    Feb 2012
    Todd
    I second the limit switch question, I'm trying to work out how many I want and where to put them.
  16. #36
    Aug 2006
    So had my first mechanical failure. I was trying to set some tool offsets and the lathe kept stalling when jogging the z axis towards the spindle. Turned down the rapid rate and it would jog, but i could hear crunching noises coming from the ballscrew fixed bearings. Sine day 1 i've known these bearings are a weak point and I've wanted to upgrade the design for a while.Today was a good excuse. Both bearing plates cracked and in turn scored the bearing pocket.
    HF 8x14 linear rail conversion....and maybe more...-20200405_100237-jpg
    HF 8x14 linear rail conversion....and maybe more...-20200405_100258-jpg
    So, i dug into my bag of bearings and found some really low profile thrust bearings. Being quite a bit thicker and larger in diameter than the original thrust bearings the bearing pockets needed to be machined out. Got out the 'ol coax indicator and made it happen.
    HF 8x14 linear rail conversion....and maybe more...-20200405_153646-jpg
    Much better!
    HF 8x14 linear rail conversion....and maybe more...-20200405_160120-jpg
    HF 8x14 linear rail conversion....and maybe more...-20200405_164933-jpg
    Attached Thumbnails Attached Thumbnails HF 8x14 linear rail conversion....and maybe more...-20200405_100237-jpg   HF 8x14 linear rail conversion....and maybe more...-20200405_100258-jpg   HF 8x14 linear rail conversion....and maybe more...-20200405_153646-jpg   HF 8x14 linear rail conversion....and maybe more...-20200405_160120-jpg
  17. #37
    Aug 2006
    Quote Originally Posted by bill south View Post
    CS900;
    Bill
    I'm semi-winging it. I do have it all modeled up in CAD, but basing measurements off a casting has it...issues...
    HF 8x14 linear rail conversion....and maybe more...-lathe-cad-jpg
    toddbeau, these motors are 380 oz-in motors from automation technologies and are geared down 2:1 (mainly for more precision)
    The Z axis limit switch is a standard roller switch that I installed in a custom enclosure. Nothing too fancy here.
    HF 8x14 linear rail conversion....and maybe more...-20200405_173423-jpg
    The X axis limit switch is a high repeatable switch from automation direct. It's advertised as repeating within .005mm and from what I can tell it does it very well.
    Attached Thumbnails Attached Thumbnails HF 8x14 linear rail conversion....and maybe more...-lathe-cad-jpg   HF 8x14 linear rail conversion....and maybe more...-20200405_173423-jpg
  18. #38
    Aug 2006
    not much progress to show. I spent quite a bit of time working my postprocessor which while necessary, isn't as cool. I did make another tool holder for another parting/profiing tool.
    HF 8x14 linear rail conversion....and maybe more...-20200412_213056-jpg
    It's made from 2 pieces, it's the only way i could get the locating notch in the correct location. I'm excited to give it a try.
    HF 8x14 linear rail conversion....and maybe more...-20200412_213105-jpg
    with all these tool holders i'm starting to wish i had made my x axis table longer....or i need to finish my tool turret...
    Attached Thumbnails Attached Thumbnails HF 8x14 linear rail conversion....and maybe more...-20200412_213056-jpg   HF 8x14 linear rail conversion....and maybe more...-20200412_213105-jpg
  19. #39
    Feb 2012
    Quote Originally Posted by CS900 View Post
    Let's see - Profile rough, profile finish, face rough, face finish, center drill, drill, tap, boring bar, internal threading, profile threading, parting..... You's need a 20" X to hold them all! Turret sounds like a better plan.
  20. #40
    Aug 2006
    Quote Originally Posted by jdrimm View Post
    I will have a turret someday....this I promise you!
