Build Thread spindle encoder for lathe
Results 1 to 6 of 6
Thread: spindle encoder for lathe
    Jan 2018
    Default spindle encoder for lathe
    hi all
    i want to make lathe as cnc conversion
    i see a lots of thing about encoder or about spindle encoder for rpm and thread cut
    but i dont know what is the best thing
    my question is... what is the spindle encoder i should to use for that
    something good .cheap and easy to setup
    Oct 2006
    Default Re: spindle encoder for lathe
    It all depends on which software and motion control vendor you are going to use. Some software (Mach3) only uses/reads one signal per revolution so all you need is a disk with one slot while others will read many signals/pulses per revolution.
    7xCNC - Minilathe CNC :: Spindle Encoder
    A simple photo interupter will give you an accurate spindle speed and the ability to cut threads.
    https://www.robotshop.com/en/wavesha...RoCbwUQAvD_BwE
    Dec 2003
    If you want a motor 'geared' off of an encoder as the way as it is done on professional systems.
    You need a Galil based, Linux, or dynomotion system.
    Jan 2018
    Quote Originally Posted by RHT View Post
    thank you for yours helping me
    i saw in YouTube using Incremental Encoders
    do you thing is good for thread
    result
    Oct 2006
    Yes it would. But, as I said, it depends on which software and motion controller you choose. Not all hardware and/or software combinations can utilize the information.
    Dec 2003
    Quote Originally Posted by anowrosh View Post
    do you thing is good for thread result
    That is what is used in the post #3 description.
